Centre Point Focus
On my camera -- which may be different than yours -- you can select the center spot (when using auto-focusing) for a particular picture -- or you can set it for all exposures by using the Recording Menu (screen #3).
In either case, you select SPOT or LOCAL.  With LOCAL, you have to choose the center spot.
Have you searched your Recording Menu?
You only need to set it through the MENU system, if that is what you want to use as a default setting.  If you want to use CENTER SPOT focusing just for a particular shot, you can quickly access it through the FUNCTION button on the back of the camera.  Again, details are in the manual.
