Alpha kit lens to e adapter
As A6500 is APS-C you can use any of them,  1 & 2 are designed for APS-C only - so if you think you might ever get a full frame camera then 3, 4 or 5 are also suited and would stop the need to get a 2nd converter.
2 & 4 have auto focus built into them - so (as Michele says) these are best if your lenses don't have SSM or SAM focussing.
My very old DT lens needs a 2 or 4
So, in conclusion, I would go for the LA-EA4, unless you find LA--ea 2 significantly cheaper, if the designation on your lens has SSM or SAM in it - I'd go for a 5.
  • 5 months later...
