A two-part question for you all:
1) with the latest DR offered by Sony camera's and the post-processing capabilities of LR, are filter systems still a necessity for landscape photography? I would imagine getting the best image OOC is preferred but am wondering out loud...
2) also, if you were upgrading your existing Cokin P holder and plastic Hittech filters to Lee, would you get the 100mm system or the Seven5? I currently have an 82mm filter threaded Canon 16-35L 2.8 which wouldn't support the Seven5 system, but would prefer to sell it in favor of a Sony prime WA if there's (ideally) one coming down the pipe. Aside from that, a 25mm Batis would be the widest angle lens I'd currently be using. Any advice from existing LEE users would be appreciated; if the Seven5 vignettes on the Batis the decision will be an easier one..
Thanks!
1/ Yes. If you spend all your DR headroom on correcting exposure differences then there is not much left for working on the actual photo.
2/ There is a thread about the Seven5 system (I started it with a similar question).
Much appreciated timde! Not sure why I missed that searching for "Filters" (I see it now though). Sounds like the Seven5 is working for you and the Batis, but if planning to go wider, then the 100mm is the likely answer
...... If you spend all your DR headroom
actual photo.
Frinstintz, the 82 series, for partial daylite
conversion, will reduce the in-camera WB
"overhead expense" when shooting by
tungsten-hued indoor lighting.
Acoarst you could use the deeper blue 80
series but thaz about 2.5 EV loss. The 82
is barely a 1 EV loss. Its original purpose
was a slight "cool down" for shooting film
at about 4pm to 6pm outdoors when you
still have daylite but it has become warm
hued daylite.
Also, there are those indoor too-warm light
sources that can take your in-camera WB
to its far limit yet the result is still way too
warm. Usually this is a scene way too dim
to spend 2.5 EV on an 80 series filter but
an 82 can keep you within, or at least near
to, correctable range at a cost of 1 EV.
Finally ... you can find a used 82 series for
next to nothing, even a huge one, cuz until
you read this, I was the only person who
realized they are still of any use !
