Sony A1 recording sound volume too high
Markfoged
Hey,
When Im recording video on the Sony A1, my audio is often too loud and clipping - even though I'm recording at the lowest possible setting. Ive experienced this with lavalier mics and a shotgun that both works fine on other cameras.
Is there a setting or something I AM missing here?
Thanks in advance
