Sony A9ii 1-2-3 Memory
I my camera there is not, but I have a different camera.
One tip -- if you do switch over to the 1-2-3 memory settings using the top dial, from the P-A-S-M settings, make sure to turn the camera OFF first.  If you don't, when you pass through the AUTO setting on the dial, the camera resets several features to the DEFAULT settings -- without warning.
Dumb design, in my opinion, so I avoid using the 1-2-3 memory settings altogether.
