A7C Will Not Restarting After Power Off
So, I purchased my A7C last December and I have only used it for filming a few times.  I have an Atomos Ninja Assassin as my monitor/recorder and I had some issues with the camera not restarting when I turned it off after filming without reseating the battery.  I sent it in to Sony but they couldn't recreate the issue.  I just recently went out and found that it only does it with an external monitor on it.  When I have my Atomos on while I am filming, if I shut the camera off to save battery while moving between shots, it will not turn back on without reseating the battery.  This does not happen when I am not using the external recorder, or even have the recorder connected without powering it on.  Once I have used the recorder with the camera on, however, even if I turn of the recorder before I power down the camera, the camera will not turn back on.  Is this a setting that I am missing or should I just send the camera back as a dud?
