Sony a7s shutter speed changing by him self...
Hey friends,
I own a Sony Alpha 7s,
Sometimes the cam start to tilt and the shutter speed goes completely crazy, it starts to dance between two values like, 200/250, and when I tried to change it just keep dancing between some values.
This happens only with the config set to the front dial of the camera... In my case I use the Shutter, but if I change to aperture the same thing happens.
Another aspect is even if I go into the menu and lock the dials, it will keep changing.
This is a hardware or software issue? This is a common problem with this camera? There is a fix?
I'm in need of great help because there is no way to work with this error. ?
Thank you guys for the attention.
