Some Problems with Alpha 1
Hi, I'm a photographer from Taiwan, and sorry for that my English is not very well. I changed my camera from Nikon D6 to Sony Alpha 1 recently, but I just found some problems of it.
1. The DRO effect won't show on the quick review when I'm using the H+ continuous mod. I have to exit quick review, and press review button again, then the effect shows. Is this because the processor not fast enough to handle so much photos in the same time?
2. When using the HDMI cable to connect the camera with a monitor, I can't review the photo on both screens. When I press the review button the liveview screen will turn black and the photo only shows on the other monitor.
3.The liveview tracking with finger touching is way more better and accurate than the viewfinder tracking with half-pressing the focus button in the same mode and settings, especially when I zoom in or zoom out the lens very fast. Why isn't there the same tracking fuction in viewfinder?
4. Coninuous shooting (mechanical) in 1/400 HSS mode will become "very" slow. There is no problem in 1/320 or 1/500, is this normal? It didn't happen on my Nikon D6 with 1/250 FP.
