Problem with sony E 18-55
eavm
Hi, a few days ago I encountered the lens losing connection with the camera at a maximum zoom of 55mm, but at 18-35mm everything works fine. I cleaned the contacts, the flex cables are not damaged. I don't know what the problem might be, if you can help please write. Attached a link to the video. https://youtu.be/utvhbVn2QfU
P.s. sorry for my english, i use google?
  • 2 years later...
Hello friend, coincidentally I have the same problem as you. You found a solution to the error of the 18-55mm Sony E lens?
