Should I still be editing in rec.709 timeline or start editing in rec.2020. Shooting 4k 10bit slog on a7siii
I recently bought the a7siii and have the Mavic 2 pro and had questions about what color space I should be editing in. I shoot both of them in 4K 10-bit LOG formats. My question is, should I be using the rec.2020 color space or still use rec.709? I feel like if I export my project as rec.709 I am not fully utilizing the 10bit color range.
