Sony A7iii hot pixel issue with long exposures?
I have a Sony A7iii and I’m aware that they suffer ‘hot pixel’ issues during long exposures i.e. red, green bright pixels in the shot, lots of them. I also know that turning on Noise Reduction During Long Exposure in the settings helps a lot, but not totally.
Question, is this something that only effects Sony cameras during long exposures at night or does it also happen during day shots, for example, a 4-minutes exposure with a 15-stop ND?
