A7rii, camera constantly taking left right up down input.
Congratulations. You need to get it repaired. Mailed A7Sii off Aug 8. Returned Aug 18. Cost $522. Under Description of Parts Used: 1) Switch Block Control 2) RL Block. Here's what mine looked like.
Edited by VTC
