Sony A7ii Camera not working
I have a Sony A7ii Camera and recently I formatted a new memory card on my camera and the battery was around 40%. During the format process, the camera turned off and when I tried restarting it again, it won't show any firmware in the camera and would just flicker once with the live view display and then go black.
I have been trying to solve this problem and have no success till now. Please help out if any of you have any idea how to get this fixed.
I had problems with the rear view panel going black on my A7ii.  In the end I tracked the problem down to a dirty sensor.  Have you checked your EVF?  If the electronic view finder works after the live view goes black, it could be that the sensor immediately above the EVF has become a bit smeared, or has become otherwise obscured.  I cleaned mine with a cotton bud dipped in the fluid I use to clean my spectacles.  Afterwards, the live view panel worked as it should.
The viewfinder looks quite clean and there is no challenge there. I tried to connect it to the laptop for upgrading firmware but the camera is not recognized as a device because it doesn't have a working os on it.
can you guide me as to how should I go about trying to upgrade the firmware again?
On 22/12/2020 at 3:13, Ibrahim Sajid said:
El visor se ve bastante limpio y no hay ningún desafío allí. Intenté conectarlo a la computadora portátil para actualizar el firmware, pero la cámara no se reconoce como un dispositivo porque no tiene un sistema operativo en funcionamiento.
¿Puede orientarme sobre cómo debo intentar actualizar el firmware nuevamente?
tengo el mismo problema con una a6300, pudiste solucionarlo?
saludos
