A6400 Questions
Stanswe
1. Yes.  C1 setting is under Camera 2->Custom Operation1 (8/9)->Custom Key->Top.  Zoom option is under menu #17.
2. Yes (I'm assuming by "water-gauge" you mean the level indicator).  EVF display settings are under Camera 2->Display/Auto Review1 (6/9)->Finder.  There will be a check box list, check Level.  When the EVF is active press the Disp button on the back wheel to cycle through the display settings.
3. No.
Too bad Sony doesn't make the menu system update-able via Firmware.
3. No.
Thanks cmycycle! Works fine now!  Rgds Stan
