rIV LCD banding problem?
hello, I noticed in low ambient light conditions and low image exposure that my rear lcd screen forms a strange "eye" shape and side stripes as shown in the images.  No, it is not flickering effect, the effect remains.  Is it the lens that creates this phenomenon?  can someone help me?  thank you
Edited by Enrico81
Does the stripe pattern change its shape/position, when you press lightly on the screen, like in a touch-screen operation? If so, the pattern is caused by some slight "inner mechanical tension", which I would consider harmless.
3 hours ago, Chrissie said:
Il motivo a strisce cambia forma / posizione quando si preme leggermente sullo schermo, come in un'operazione touch-screen? In tal caso, il motivo è causato da una leggera "tensione meccanica interna", che considererei innocua.
Thanks for the answer, I found out what it is, I deactivated the lens compensation option and deactivating it the "eye and lines" effect disappears!
