a68 only shooting B&W at any setting other than AUTO
Sony a68, new December 2019, started only shooting in a modified B&W when I took it out today.  The sensor sees some bright yellows but everything else is B&W or shades of gray.  I pulled the memory card and it is the same in Lr; all grays and only some yellow showing.  When I switch to AUTO the color is fine.  Have I changed a setting accidentally that is causing this?  The grass is very green in the yard, but only the yellow flower stand is in color.
Received an email from Sony Support.  Seems I had inadvertently turned on Picture Effects>Partial Color>Yellow somehow.  Went into the menu per their instructions and everything is back to normal for Manual and all other modes.  Thank you Sony Support!
