SELP18200 question, problem with SEL18200
rosak
Hi, I have just purchased SEL18200 to film my bench while I'm working, however it turned out to be unusable as it retracts itself and can't be locked, please have a look:
My other lens SEL18135 doesn't do that but it's obviously lighter.
I wonder if SELP18200 has the same problem, so would be very grateful if someone can check that for me before I spent another $900 or so.
Thank you very much in advance.
The 18-200 you have should have a zoom lock switch which locks it in the 18mm position, preventing any zoom creep. Can't be used at any other focal length afaik.
Do you need a lens that goes up to 200 mm? The 18-105 f/4 is internal zooming so doesn't extend and for sure doesn't suffer from zoom creep. Then again, if you already have the 18-135 I guess you do...
I have no experience with the 18-200 power zoom but Internet tells me that if you engage the servo zoom, it should keep the lens in place:
https://www.sony-asia.com/electronics/support/articles/00008353
Edited by Pieter
