Sound after turning off my a6500
Always or occasionally? About once every couple of weeks the camera takes a photo with the shutter closed when you turn it off, to map hot pixels on the sensor. This should only be occasionally but otherwise acts as you describe.
Thanks for your replies. This morning, I've been in the store to test this behavior on another a6500, and it was the same. I guess indeed it's some mechanism to lock the sensor once the camera is turned off. This happens about 3 or 4 seconds after power button is switched off.
Edited by mg10
