Hello,
I have myself a a 77ii and just got my 400mm 5.6 macro from sigma.
They said it should autofocus whitout problem but it doesnt.
I think the video would describe the video and show how strange it is.
http://youtu.be/7Jf5ny2juIM
Can someone tell me what is wrong whit my settings/the lens or camera.
Because it can focus but not whitout focusrestriction which is build in in the
camera.
Greets Jens
p.s. i set the af motor to slow so if somethings broke it wont brake it as soon.
The problem is when i dont use the in body focuslimiter it focusses always closer and if the lens is at minimum focussing distance it wont go back to infinety but the lens makes that weird sound. The weird part is when i use the lens focus limiter it happens already at 3.5m that the lens get stuck when i use the in body limiter it goes to around 2,5 meter whitout problem and then it will go back to infinety.
Greet jens
    • Shooting a cactus flower is probably where you do want to have nice bokeh. I can't recall which camera you're shooting, or maybe you haven't said, but using live view you can see what the shot will look like before you press the button. Try setting up on a flower or something stationary where you can control the background and see the changes different settings make.
