Sample images from the Tamron 17-28, GM 16-35 and Laowa 15mm
If you are interested in seeing some samples from the Tamron 17-28 with the same images taken using the GM 16-35 and a Laowa 15mm
You can go here: https://www.jakesloan.com/photos-for-download to see the jpegs and there is a link to download the raw files as well.
I haven't had time to label them but the meta data is there if you use a program like Lightroom.
Here are a few samples
Edited by Jake Sloan
embedding
