Dead A7, could be battery thing?
Help! I have an A7 and an A6000. I cleaned the sensor on both today using the VSGO kit. When I was finished I tried to turn them on. The A7 was completely dead. Changed battery, Dead. Same again with the third battery. I would expect these would all be 70 to 90% at this point. I tried the A6000 with a fourth battery (already in the A6000) and it worked. I moved that battery to the A7, dead. Put it back in the A6000, dead. Removed the last strands of hair from my head. I put the battery that had worked, back in the A6000. Dead. I swapped lenses on the A6000 and turned it back on. Worked. Put that battery in the A7, dead. It appears the A7 is fooling the battery into not working. Any ideas would be very gratefully received 1f642.png:)
