70-200 f2.8 GM A9 Noise when shooting
Just got a 70-200 2.8.  When I'm shooting with the A9's electronic shutter the lens makes an audible rumbling noise with a slight vibration on every frame shot.  I've turned the optical steady shot off and get the same behavior.  Wondering if this is normal behavior?  My other lenses do not seem to do this.
