ErikB
Sony alpha 3rd party lenses
Advertisement (gone after registration)
Hello,
I am a new Sony user. I decided to get the A7ii since I am a beginner. It was on sale for a good price. I have winced learned that Sony glass is expensive. What are good 3rd party lenes. I know sigma as a brand. I am not familiar with ronikon or other brands. Are any of them worth buying?
Share this post
My experience with Sigma has been very positive.  I would suggest you determine a list of focal length primes or zooms you wish to consider, then do some searching for reviews and opinions for individual lenses.  There are many superb non Sony lenses available.  Once you have arrived at a want list, then I personally would buy used on Ebay (where you can get a full refund, even if the seller won't accept returns)
Remember that many of the non native  lenses will be manual focus, that auto focus with non sony lenses can be problematic...so you have to do some research.
Share this post
Sigma lenses are great for image quality and sharpness but the only downside is that Autofocus isn't reliable, especially for video. I've had the 35mm and the 50mm using the MC-11 adapter on my a7ii and it will hunt quite a bit sometimes. If you're willing to use Manual Focus most of the time I'd say go for it. Keep in mind I always kept my lens, camera and adapter updated with the latest firmware.
Samyang and Rokinon are pretty much the same company with different names. They have the manufacturers so there would be no difference in choosing one brand over the other.
I have the Rokinon 50mm  F1.4 and the AutoFocus is barely usable especially in AF-C. My lens isn't update so that maybe the reason. I wouldn't buy it unless it's updated or if you are planning to get the Lens Station for future updates.The colors on the Rokinon were a little weird to me too. The photos come out slightly more yellowish/orange and sometimes acts up even with a color checker passport.
All in all, if you're interested in third party lenses, I'd look at Sigma because image quality, detail, distortion, and colors are far better than Rokinon and Samyang.
Hope this helps!
https://elgopro.myportfolio.com/
https://www.instagram.com/elgopro/
Share this post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
    • Hola. Buen Foto, perro apperece demasiado frio para mi !
    • A7R3 + batis 85 Hello guest! Please register or sign in to view the hidden content.
    • I had my first A9, replaced within a month or so of purchase, because the switch was defective. The only way, I could get the  LCD to work,  was ...by pulling it away,   from the back of the camera. Otherwise, I had to do everything through the viewfinder, which was not easy. I am not saying  its the same problem, but mebbe worth a try ? I bought  the A9 through a Jessops branch, and they agreed that  that should not happen in a camera costing over  4 grand. The replacem
    • Facundo. Primero, desde  su foto, la pila  es agotado ! Segundo, no hay tarjeta  SD.  Vamos a cargar la pilla , y intentalo de nuevo, con tarjeta de  SD montado. Si a veces, un ISO alto, puede salvar un opportunidad, perro en este caso  no sale bien. Probarlo de nuevo con menos ISO Suerte.
    • Hard to explain in a headline, but basically I got my a6000 three months ago and it’s been working great. Lent it to my sister-in-law for a weekend and since then it’s charging has been so weird.  Plugged in, the light by the mini USB doesn’t turn yellow. The top right battery indicator also shows nothing.  But leave it alone long enough and it does seem to charge, although the better doesn’t seem as long lasting as before. The camera is also registering the USB as there since it goes
