Andrew Posted February 17, 2019 Share Posted February 17, 2019 Considering buying some Canon glass and an MC-11 adapter. I was just wondering does the lens stabilisation work with the MC-11 Adapter? Also how well does the Canon 70-200 f2.8L Lens work on an A7 III? Well enough for moving subjects using AF-C? Link to post Share on other sites More sharing options...
elgopro Posted February 21, 2019 Share Posted February 21, 2019 So, if you get the IS version of the Canon 70-200mm F2.8 Series, the lens stabilization will work but not the same way it would on a Canon body. If you mounted that lens on a canon body that has IBIS (In Body Image Stabilization), the lens would be used as an additional axis of stabilization. On a sony body, that would not be the case. It would work less efficiently and minimal difference would be shown. The AF-C is pretty good so far but I have to test it a little bit more before making a judgement. According to DXOMark, The non-IS has better picture quality than the IS version. I have the non-IS and still need to use it more to analyze consistent picture quality. I think both Stabilization and Image Quality are barely distinguishable. If I were you, I'd get the Non-IS because it has slightly better picture quality, the IS makes little to no difference, and it is cheaper to get the Non-IS. Ill try sending a few images once I have them ready. Here are the ratings by DXOMark https://www.dxomark.com/Lenses/Canon/EF70-200mm-f-2.8L-IS-USM https://www.dxomark.com/Lenses/Canon/EF70-200mm-f-2.8L-USM Hope this helps! https://elgopro.myportfolio.com/ https://www.instagram.com/elgopro/ Link to post Share on other sites More sharing options...
