a7II customize rear dial for ISO
oneeye
When I have to shoot fast in photo journalism, I don't have the time to bother with A or S, so I use the P setting and adjust using the front dial for a compromise.  But sometimes there is not enough light so I have to lower the camera, redial the ISO, set it and then, again, find my subject focus and shoot  -  and the picture is usually gone by then.  It seems to me that the two - front & rear dials work the same, a waste of a useful feature.  So, I would like to know if it is possible to customize the rear (only) dial to change the ISO.  That way I can keep the subject in sight while only turning one of two dials to set everything needed for a fast shoot.  This would work well, but I don't know if it is possible with the current software.
Any suggestions?
Thanks.  I know I can set the ISO to auto but the separate use of both front and rear dials - rear for ISO - would be a great feature,  just like customizing the buttons.  Too bad Sony doesn't have this customization feature available for these dials.
  • 3 years later...
I don't know about your camera, but on mine, if I press the ISO button with my index finger, I can immediately and easily change the ISO with the rotating rear dial using my thumb.  Perhaps yours operates this way as well.  Perhaps not.
9 hours ago, nadirki550 said:
I find it very difficult to rotate it without pressing one of its button functions.
The Rear wheel on the A7II is recessed further away than the optimum position because the slope of the body below the dial is too shallow.  If you look at A7III, you can see the slope is much more steeper bring the real dial closer to the thumb.  And then having the C3 button so close to the dial doesn't help the situation either.  I end up accidentally pressing the C3 button if I am slightly more aggressive in turning the dial.
The only thing you can do is to train your thumb to become familiar with the rear dial's position and remember where the C3 button is located.  Turn the dial lots of times so it becomes more responsive.  For the first while the dial was hard to turn but it gets easier when you work the dial back and forth.
