Some Buttons not working in a7sii looking for hard reset
Recently the record and middle button on the Dial/Wheel on my a7sii just stopped working. without that middle button i can not select anything on my camera so i can't access anything on the menu like the Setting reset cause basically i don't have an "enter" or "select" button.
i can scroll through the menu but cant select anything so i cant reset from the menu so I am searching for a way to reset to factory settings without using the menu, and i don't think there is a reset button on the body. So if anyone can help with a way to reset like sometimes they the "turn on while pushing down XXX buttons". if anyone has that info it is very much appreciated
Jorge González
  • 5 months later...
Jorge González
Did you fixed this?   i have the same problem
On 6/7/2019 at 8:42 AM, jorgephoto said:
I took it to a Sony workshop, they had to replace a couple parts and cost around 120 dollars
Could you be more specific please? Which parts have been replaced? I have the same problem and I would repair it by myself!
Thanks!
  • 8 months later...
Damn it guys.
I have an a7r2 and have the exact same issues! Is Sony really making this many mistakes? Record button stopped working a week ago. Then today, the controlwheel stopped working and the select button in particular.
Thanks!
Basically they said a "flex" was damaged and that it would cost like $70 in parts and $50 for labor
  • 1 year later...
  • 8 months later...
