Flash compat. issues
Reemo
Hi,  love the Alfa 6000 , my first  proper camera again since the analogue era.   BUT  apart from the camera used as a shoot and play ,  i wanted to dive in playing with light and flashes again ....so i got myself a nice Sigma EF610 DG super (with Nikon shoe)  obviously  physical fit but no much flashing apart the test button ;)   , so i got a HC512 hotshoe adaptor made in ...well yaknow....  for Nikon to Sony...now the flash gets triggered BUT  no TTL ....Hmmm  ..... no  "D"  on the flash  LCD (to indicate connection) ...   now the Sony shoe  has like a ton of tiny connections (probably to launch a small rocket by wire ???) and the adaptor  uses obviously a few to translate to the flash through the 4 plus ground pins ......it all feels a little bit wobbly...  anyone experiences here ??    tips tricks ??  thanks
Edited by Reemo
