Pentax 135mm F3.5 or Sony 55-210 for landscapes
ScottTilley
Hi, sorry if this type of question has been asked before! I have a Sony A6000 with the kit lens but would like something a bit longer to compliment it for landscape shooting. I could wait and save for the 55-210 but wondered if something like the Pentax would be a good alternative at a bargain price. Currently it looks like a good copy with adapter will set me back less than £50.
Thanks.
Scott
  • 1 year later...
  • 2 years later...
