XLR-K2M issue with handheld microphone (Sennheiser e865)
Hi,
I'm a journalist and I got some audio issues when filming interview with a Sony A7 II + XLR-K2M + Handheld microphone Sennheiser e865.
Firstly, i must say that the same audio equipment (XLR-K2M + Sennheiser e865) is working properly on my Sony FDR AX100.
So, i get this weird sound when isolating the handheld microphone channel :
https://send-anywhere.com/web/downloads/6FISNUKM
The problem occurs only when the background sounds are high (example : a protest in the streets). Also, I don't have this issue on the channel of the XLR-K2M kit microphone.
Thanks for your help !
Pierre
