Alpha A55 and Sigma Ringflash
I have a Alpha A55 and have just acquired a Sigma ringflash. I have discovered two quirks. First it will only work with the Sony kit lens and not my (old) Sigma 85mm Macro lens. Second, it only works in Fill-flash mode and when the built-in flash is open!
I would like to buy a nice macro lens (such as the Tamron 90mm macro), but I would like to be sure that it would work with my camera/flash combination. Does anyone have any experience?
John Rostron
