kamajan999 Posted August 30, 2017 Share Posted August 30, 2017 Is there any real practical difference in IQ? According to DXO they are pretty much the same except for high iso where the D610 have an advantage, but is that advantage big? Is it even noticable? Is it worth to even consider the D610 over the A7? Im confused! Link to post Share on other sites More sharing options...
Advertisement Posted August 30, 2017 Posted August 30, 2017 Hi kamajan999, Take a look here Sony A7 vs Nikon D610. I'm sure you'll find what you were looking for!
Username Posted September 5, 2017 Share Posted September 5, 2017 ` I use both. They are both very good but for OOC jpegs the 610 is visibly better. IQ is not a worthy goal, it's a distraction. I neeeevvvver check out or DXO or any similar data. I CANNOT say that all my lenses deliver equal results, but I CAN say that DXO etc are toadally incapable of predicting the keepers. Link to post Share on other sites More sharing options...
kamajan999 Posted September 5, 2017 Author Share Posted September 5, 2017 ` I use both. They are both very good but for OOC jpegs the 610 is visibly better. IQ is not a worthy goal, it's a distraction. I neeeevvvver check out or DXO or any similar data. I CANNOT say that all my lenses deliver equal results, but I CAN say that DXO etc are toadally incapable of predicting the keepers. How many % roughly would you estimate your D610 is doing better than the A7? Btw, I only shoot raw. Link to post Share on other sites More sharing options...
Guest Jaf-Photo Posted September 5, 2017 Share Posted September 5, 2017 The sensor is the same. Nikon has a different colour style with slightly less warmth and saturation. But if you shoot raw, you can tweak that. If you're choosing between the two cameras, it may be more useful to take a system view. Factor in lenses, accessories, performance, size, weight etc and make your choice based on that. Link to post Share on other sites More sharing options...
Username Posted September 9, 2017 Share Posted September 9, 2017 How many % roughly would you estimate your D610 is doing better than the A7? Btw, I only shoot raw. I did specify I was speaking of OOC jpegs. For raw there's no important difference. If you want a "%" estimate about the better jpegs from Nikon, I can use a different way than "%" to offer a quantitative answer. Consider how increasing ISO will gradually "rot away" visible [eyeball judged] IQ. Consider the effect of going from 800 to 1600 or going from 1600 to 3200. I'm using that "upper midrange" here cuz a change from 100 to 200 or 200 to 400 is noticeable, but doesn't leap out at you, cuz those are all fairly high IQ ranges. But when IQ "rot" starts to be very visible even on casual inspection, you REALLY see the effect of doubling your ISO quite unmistakably. So OK, let's call the 800->1600 bump, or even the 1600->3200 bump "one full IQ step". Depending on BOTH the level of detail AND the amount of smooth tone in the image, the 610's advantage over the a7II is approximately "one full IQ step". Certain images look to be less than a 1/2 step. Others look like way beyond one step. One full step is only an average, and again, this is for jpegs judged by eyeballing the overall image, plus some peeping. For raw images, I've read that Nikon's greater bit depth allows more extreme correction of images that demand quite a bit of extra DR. But in my own use, I find no need or use for that. Perhaps I shoot scenes that are less demanding "DR-wise" ? A non-quantitative description that I have used in discussions about "eyeballed IQ" is that if one gets used to Sony jpegs, then the Nikon jpegs seem like OOC direct tiff files. This is not just a casual visual assessment. I can definitely say that Nikon jpegs will tolerate more tonal "push" or "pull" before they show telltale digital artifacts like peppering or a "tiled" look. Clearly this is all about the "jpeg engines" cuz with raw files, the differnce is too small to concern me. I'd give operational features more importance than any difference in raw flles ... for MY use. YMMV. I've read some very negative rants about Sony's lower bit depth and their compression scheme. I put no faith in ANYONE's opinion or observations when it is delivered as a RANT. I have never seen negative remarks about Sony raw files that were NOT in rant mode ... so take that FWIW :-) Link to post Share on other sites More sharing options...
kamajan999 Posted September 10, 2017 Author Share Posted September 10, 2017 So if I expose "correctly" as I want it in the end and maybe adjust minimal (Max 1/3 stop push or pull) I should see no practical difference in IQ no matter what iso setting. Link to post Share on other sites More sharing options...
Username Posted September 10, 2017 Share Posted September 10, 2017 So if I expose "correctly" as I want it in the end and maybe adjust minimal (Max 1/3 stop push or pull) I should see no practical difference in IQ no matter what iso setting. " .... no practical difference in IQ no matter what iso setting." That would be for raw files. For jpegs you wouldn't likely notice a difference from 400 ISO on down, but from 800 upward the D610 will allow double the ISO at the same IQ as the a7II. IOW Nikon's ISO 1600 IQ looks as good as Sony's ISO 800 IQ, given a typical scene involving both in-focus details and smooth tone areas. I'd never accept a camera that can't do raw files, but not cuz I'm into processing them. To me they are insurance against disaster, like a life jacket or parachute. I'd be uneasy without them, but I've become the "jpeg maestro" cuz so many cool in-camera features are jpeg-only. Acoarst in order to avoid deploying life jackets or parachutes one must steer clear of icebergs and ice storms in the first place ! And it's also beneficial to fly a DC-3 rather than a BizJet :-) If you can't get there at 180 knots, mebbe you should reconsider whether it's worth going at all. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! The retirement age for DC-3s is as yet unknown, but we do know that the workers who built them retired and died long before your mama was even born, maybe before your grandparents had met. They are as obsolete as cockroaches. It's something to consider any time you're afflicted with GAS :-) FWIW, jpegs from the 610, and also the 750, range 9MB to 15MB vs 5MB to 8MB from the a7II ... and both cameras have the same pixel count [24MP]. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! The retirement age for DC-3s is as yet unknown, but we do know that the workers who built them retired and died long before your mama was even born, maybe before your grandparents had met. They are as obsolete as cockroaches. It's something to consider any time you're afflicted with GAS :-) FWIW, jpegs from the 610, and also the 750, range 9MB to 15MB vs 5MB to 8MB from the a7II ... and both cameras have the same pixel count [24MP]. ' data-webShareUrl='https://www.sonyalphaforum.com/topic/7910-sony-a7-vs-nikon-d610/?do=findComment&comment=35617'>More sharing options...
kamajan999 Posted September 10, 2017 Author Share Posted September 10, 2017 I only do Raw Link to post Share on other sites More sharing options...
kamajan999 Posted September 10, 2017 Author Share Posted September 10, 2017 I have been struggling with GAS for many many years, BUT I think I finally settled down a little bit. Since I got the A7 (mark 1) for a couple of weeks ago (My local shop had a super deal on it) (As well as using my D800E which I am not interested in trading in for the D850) I am calm, maybe it comes with age? However, I really appreciate all the input, not that I would get rid of the A7 for a D610, just that I'm curious and interested in both the artistic and technical side of things Btw I have been having super fun doing bokeh panoramas with the A7 and manual lenses Link to post Share on other sites More sharing options...
Guest Jaf-Photo Posted September 10, 2017 Share Posted September 10, 2017 I have been struggling with GAS for many many years, BUT I think I finally settled down a little bit. Occasional bouts of lethargy are part of the affliction Link to post Share on other sites More sharing options...
kamajan999 Posted September 10, 2017 Author Share Posted September 10, 2017 Occasional bouts of lethargy are part of the affliction Link to post Share on other sites More sharing options...
