A6500 Gimbal Users... What Lenses?
So I have an A6500 that I use with a Zhiyun crane.  Together they produce amazing footage.  So far I have used the 10-18 lens and 16-50. I recently purchased the 18-200 PZ lens hoping to be able to use it with the gimbal but it won't really work without some modification.  Not to mention since its a telescoping lens the weight would shift quiet a bit.  Instead I'm going to try to get the 18-105 f4 PZ lens to keep as my main "run and gun" lens.  Anyone one else used this combo?  I really like having powerzoom since its near impossible to manually zoom with a camera mounted on a gimbal while still keeping steady...
