Hi Guys,
              I am new to Mirror less cameras , I bought a new a6300 and i was testing the 4k video. And the shows a lot of frame drops and stuttering while panning. I dont know which setting needs to be adjusted to rectify this or whether it is indeed how 4k video is recorded within the a6300. I have uploaded a sample 4k video from the camera
. I have also uploaded a 1080p 50fps video of the same scenario which has no such issues https://www.youtube.com/watch?v=jdNV7RJ_vOc. Can someone help in figuring out what settings I need to change inorder to get smooth 4k video out of this. I am thinking about returning this camera and getting a canon 80d if this is actually a drawback of the camera.
Regards,
Bince
