I have messed something up. Please help
In "P", "A", and "S" when I press the shutter it rapid fires like it is taking multiple exposures and then says "processing."  It hasn't been doing that.  I have looked through the menu items trying to figure out what I have done and I don't know.  Please help.  Thanks.  Sony a6000.  I go to drive mode and single shooting is grayed out and says that that setting is not available.
Drive Mode allows you to specify the number of shots each time you press the shutter button
You can view the manual here : https://docs.sony.com/release//ILCE6000.pdf
Actually, I figured it out.  I had set it on the wrong ISO.  I had it on ISO Auto "Multi Frame NR"  instead of just Auto ISO.  Not sure how that happened.  If it is set on Multi Frame NR that over rides the Drive mode operation and it automatically fires of a whole lot of shots, when set on P, A, & S.  Thanks for your reply LiveShots.  I appreciate your help.
