Sexy Sony a7R, Zeiss Planar T* 1,4/85 ZF.2 and Novoflex adapter
SAR_admin
Works fine since many years on my CONTAX RTSIII, CONTAX AX, CANON 5DMkII,  and now on my SONY A7!
