A5000 flash overexposure
I recently acquired a A5000 which works well with no problems except I can't seem to get the flash not to overexpose no which which shooting mode I use or flash mode.
Am I missing somethng?
Thanks,
barham
Thaz not much to go on.
To hope to solve it form so little info, any respondent
would hafta ask zillion detailed questions. Let's try it
one question at a time ... The green mode, the PhD
mode, should cancel any non-default customizing
that you may have done, intentional or accidentally.
If you shoot a Very Ordinary scene of very little depth,
in the PhD mode, do you still have roughly the same
degree of over exposure [as shown in the histogram] ?
Tho the above can be answered "yes" or "no", you'd
do well to add more info, plus some example images.
Thanks,
barham
What of course, immediately comes to mind, is that you have flash compensation jacked up?
Could very well be that. Or not. Thaz why the
Green Mode test is Step One .... cuz it cancels
ALL that stuff. If Green Mode exposes properly
then it's time to chase down accidental settings
by the user .... and certainly THE most likely of
all errors is the very one you suggest.
Reason I'm kinda persistent about the Green
Mode is that it's available without diving into
the menus where some new users might even
pile on a coupla more accidental errors. IOW,
it's "PhD proof" :-)
If there's some exception to my understanding
of the "total override" nature of the PhD [Push
Here, Dummy] mode, I'm all ears ! My only use
of it is for video, cuz my use of video is usually
limited to the PhD snapshot level.
