A7ii Peak level on external monitor
Hi
I have just place an external monitor on my A7ii for filming. It works like a charm and with the battery grip it's really really steady.
Since i'm using a vintage Nikon lens I am counting on using Peak Level to focus, but I'm not seeing this on the monitor.
Does anybody know if I can get that to show on the MustHD ext monitor?
Looked at the specs of your monitor and shows it's capable of displaying peaking so it may be communication problem between the Nikon lens and the camera. Try a lens not requiring any adapter and see if peaking renders on the monitor that way. Does it render peaking properly on the built in monitor but not on the external? If not I suspect it's due to the dinosaur glass &/or adapter combination.
I use a SmallHD monitor for focus on macro shots and it's far more accurate than anything I can pull off the rear monitor. (A7Sii)
