Sky Falls Down with Melanie
DigitalMinds Photography
+++ SKY FALLS DOWN WITH MELANIE +++
Currently i am still testing some old lenses on my Sony Alpha 7 Camera and i am quite happy with the image quality and the "look" of the lenses. This pictures are taken with a Revunon 55mm 1.2 lens at f2. (blog entry)
Are you also using adapted old lenses?
bbres-MnxCb3Vkb2lyLzIwMTcvU2t5IEZhbGxzIE
Feel free to check out the complete series with Melanie on my Website ;-)
