Does your SEL55f18z make sound when shaken?
I'm sorry if this has been asked before. I tried searching but can't find similar topics. My lens makes sound when shaken, like something is loose inside. When comparing it to another SEL55f18z it also made a similar sound but it's much quieter. I was just wondering if yours does the same. Everything is fine it's just the sound is kind of driving me crazy. :(
Yes mine makes a slight rattle. No problem in use though.
