Sony a6000 display problem need help
hi my a6000 display got damaged and shows nothing only from viewfinder , but today a friend of mine played on the menu from the viewfinder and changed to monitor only now i cant even view from the viewfinder , would anyone help me what  to press blindly step by step to change it back to viewfinder only , and i have no hdmi connector so i cant use a monitor i'm screwed. thanks a lot for any help
Have you gone to menu>Settings (gear icon) >tab3  FINDER MONITOR and set to Auto?
This will allow you to use both together based upon how close your face is to the viewfinder window.
It sounds from your description as if you are now wet to Monitor only, previously on Viewfinder only.
and set to Auto?
is to the viewfinder window. It sounds from your description as if you are
As per your reply, yes, he IS now set to "Monitor only". Soooo,
unfortunately he cannot follow such instructions, cuz he can't
use the monitor due to physical damage :-(
Worsely, there's no set of instructions for a careful blind button
pushing sequence cuz there is no way to know from where the
effort would commence. "Cain't git thar from heah" is not a joke
when one cannot first determine whar "heah" actually is.
This puppy is definitely due for a trip to the vet.
  • SAF Admin changed the title to Sony a6000 display problem need help
