Using DX Lenses
Can you use Nikon DX lenses with cropping turned OFF so you get a full 35mm image but with vignetting?
I have a DX 18-200mm that I'm hoping to use with my A7 coming tomorrow. Any advice or suggestions like should I shoot if possible with cropping OFF and then crop in post?
Thanks for the encouragement but it seems to be no, no, no!
My DX 70-200 has no manual aperture adjustment and stays
at f/16 until the passing of time. The Metabones can do nothing
to help.
OK. I just went and looked at an 18-200 DX [only DX
on hand ATM] which lacks an aperture ring BUT ... it
still uses a mechanical auto iris lever. So with such a
lens one needs the adapter that feature a manual
iris control ring. Such rings are marked not in f/stops
but simply in consecutive numbers, so you know how
many stops away from wide open you are setting.
I might just jam a matchstick in there to keep the lens at f5.6 and
expose with ISO. What you think of that? The resale value of this
lens is only about $200 so silly not to try to use it if I can.
The adapters with the iris control are not in the same
class or price range as the Metabones. For $40 +/-, I
just can't see stuffing anything into the lens's action.
The Iris control does work, despite a rather trashy
feel to it. The lens latch is sloppier than the one on
the Metabones. It won't let go, but there will be just a
little rotational play. Also the rear flange is will not be
chromed brass but simply machined directly onto the
same hunk of aluminum from which the adapter body
is machined.
Forget the resale value of the lens, but  please don't
think I suggest ignoring value and cost. If you will get
about $40 use-value [basically images accomplished]
from the adapter, get it. Otherwise cash out the lens
if you have no other use for it.
F.Y.I. I use all my old and new nikkor lenses on the A7ll...mind you I am using a "cheap" but very good K&F Concept adapter. G version.
Aperture works great on ALL lenses. Not sure why people ever, ever, (pay big bucks) get a Metabones adapter.
You have to watch the focal distance. on my Tokina 12-24 I can only go from around 18 till 24
............ I am using a "cheap" but very good ..... adapter. ........
Cuz $75 dollars is not big bucks for a better adapter. I
did use a non-Metabones for a coupla weeks and it did
work quite well. But the Metabones addressed all of its
shortcomings. Fortunately I never actually owned that
first adapter, so I never hadda pay for my own mistake.
I payed only once ... for the Metabones.
But, I know eggzacklee how you feel. I myself cannot
imagine why anyone would pay more than double the
price of the Metabones to get the Novoflex !
I have owned two metabones (II and III) and one King ($79) and the King equals or in some cases outperforms the Metabones (faster auto focus with my 28-70 2.8).  In my opinion they are far over priced, although I got III for $125 on Ebay.  There is no real improvement in III vs IV other than "flocking" the interior which might improve the performance shooting into the sun.  Again I kept the cheapo, sold the overpriced bones.
