memory function for different custom key settings
Does anyone know if there is a kind of memory function on the Alphas (e.g. on the a6300 and a7m2) for different custom key settings for different lenses?
When I mount an MF-lens, my custom key settings are entirely different from when mounting a AF-lens. Also for different focal lengths of AF-lenses, my setting is partially different. It is a bit of frustrating to switch everything back manually when changing lenses. Is there a memory function for the Alpha cameras that detects which lens is mounted and automatically switches the custom key settings respectively?
If not, any idea where I could address this suggestion to Sony? Might be possible to implement by a firmware upgrade (?).
Many thanks!
blattboldt
