Low resolution quality warnings
How can I get the a6300 to load a resolution of at least 2000p? Every site I want to market my pictures tell me the resolution is too low and they won't accept my photo? 1920 is the highest I can push it up to. My iPhone is showing a higher resolution even though it's picture quality is terrible in comparison
Very odd. As I recall the a6000 produced a MUCH higher resolution. I'll check when I get home. Most APSC SLRs do.
I'm assuming you've set the resolution to "Extra fine"?
It may also be the method by which your sending or uploading the photos to them. Many of these programs will automatically shrink files. (even though they won't tell you this)
Yahoo will still outright reject me sending photos from my oldest Sony, an A33 as being too large. This is why I suspect they're being compressed.
How are you sending the photos to them?
