A-6000 firmware issue ???
I'm really hoping Sony assigned someone to regularly check
this forum. This glitch involves something that they would not
ever have thought to check, but in real use, it's a problem.
The MR [memory recall] mode on the A-6000 is very useful.
Like many users, I use "back button AF' meaning I've moved
the AF activation OFF of the shutter button and assigned it
to a button on the rear of the body [AEL in my case].
Like many users, I go thru batteries like madness. Yes, you
can shoot hundreds of frames on one battery, if you avoid
using going into the menus, checking sharpness with the
playback magnifiers, etc etc.
THE GLITCH:
If you change a battery while in MR mode, upon inserting a
new one and switching on the camera, the "AF by shutter
button" will reactivate itself.
DETAILS:
I've checked my procedure very thoroughly. The glitch is
tied to the mode dial "MR" setting when powering up after
a battery swap. IOW, even if the dead battery is removed in
MR mode, and a new one is inserted, IF you switch OUT of
MR mode before power up, the "AF by shutter button" will
NOT reactivate itself. Switching back into MR mode at this
point is OK, it will not reactivate AF by shutter button. It's
all about the mode dial setting at the moment of powering
on the camera [and only after a battery swap out].
Using rear button AF is not rare amongst users, nor is it
rare to go thru batteries quickly. No problem with those
two user habits in combination. But two's company and
three's a crowd. Add a 3rd user habit that happens to be
favoring the MR mode, and now you hit the glitch. I don't
really know if MR mode is popular or I'm one of very few
using it ... so I don't know how much the glitch matters in
The Big Picture to Sony. But clearly this is not something
Sony would have ignored had it been encountered during
development. But it's perfectly understandable that they
never happened to test the result of this sequence of user
operations as it impacts the many custom functions a user
might have engaged. But back button AF is a commonly
engaged custom function, so I hope this gets addressed.
