Red Kites @Gigrin Farm, A77ii + 70-400 G2
PaulHobbs
Hi All,
Here are a couple of snaps of Red Kites taken at Gigrin Farm in South Wales.  I used a Sony A77ii and a 70-400 G2.  I previously visited Gigrin with the 70-400 G2 mounted on an A7 with LA-EA4 adapter but found the setup to slow to cope with the fast moving flocks of birds.  The A77ii handled it admirably.
