First Mirrorless Experience - Sony a7RIi
Received my first Mirrorless camera (Sony a7RII) a few weeks ago. Doing well to understanding & using the menu. Good resource has been Brian Smiths book: "Sony a7 Series - From Snapshoot to Great Shots."
Working through or trying to wrap my head around when to use & not use Auto ISO. Add in setting up Memory recall. I always shoot in manual mode.
Happy to be here and looking forward to learning a great deal!
Rick
