JCgarvayo Posted August 6, 2016 Share Posted August 6, 2016 Dear friends, I just "inherited" all these Nikon lenses and I wondered if there are any reliable adapters to use them on my Sony a6000 camera... Thank you so much for the feedback! Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.sonyalphaforum.com/topic/5726-adapters-nikon-af-d-to-sony-e-mount/?do=findComment&comment=26412'>More sharing options...
Advertisement Posted August 6, 2016 Posted August 6, 2016 Hi JCgarvayo, Take a look here adapters Nikon AF d to Sony E mount. I'm sure you'll find what you were looking for!
MikeK Posted August 8, 2016 Share Posted August 8, 2016 Congratulations on your inheritance! I can't answer your question about the adapter, but all of the "D" Nikon lenses use a mechanical screw drive to focus the lens elements. Some Nikon camera models have a focus motor built in to the camera body to operate the screw drive. Later AF-S lenses have the focus motor built into the lens. I am new to the Sony product line, but have used Nikon equipment for a long time. I doubt you will find an adapter to make use of the focus screw drive, but you should be able use the lenses by manually focusing them. The PC lens (perspective control) is a unique lens in this collection and should be completely manual. For what it's worth, the 16mm fisheye lens is still marketable if the lens is complete with the four filters and separate filter case. I sold mine last year for $500. Link to post Share on other sites More sharing options...
mkg3 Posted August 9, 2016 Share Posted August 9, 2016 The DC 135/2 AFD is a special lens too. The Commlite/Vello AF adapter should pass along EXIF data, since there are electronic contacts but will not AF any of these lenses. If you don't care about that much, then just about any F to E adapter should work MF. Link to post Share on other sites More sharing options...
Golem Posted August 11, 2016 Share Posted August 11, 2016 The only lens there thaz NOT special to some degree is the 28-105 general purpose zoom normal lens, aka "kit lens". Pretty much justifies buying a Nikon FF body. I'm basically a Sony camera user with a lot of Nikon lenses, and almost no Sony lenses. Much as I enjoy the Sony cameras, I also wound up with a new Nikon D610. It's a really good camera, same price as an a7-MkII and you don't need an adapter. I don't even like SLRs, but all my old Nikkors are fully functional on the D610, more than I can say for any adapter available for Nikkor to Sony-E. As I've mentioned, all but one of those lenses is rather special, but only when used for full frame format. As an example, you have a 28/1.4. On FF it's a very fast true wide angle. But on APSC it's just a huge bulky normal lens, still fast, but waaaay bigger than is reasonable for the APSC format. Even the fisheye won't be fisheye any more, just an ordinary medium speed wide angle with a reeeeally objectionably visible case of barrel distortion :-( Link to post Share on other sites More sharing options...
