LA-EA4 problem with tripods and monopods
As Michael_j says above, also the larger A mount lenses have their own tripod mount.  Use the other tripod mounts before using the one on the bottom of the camera and you should be good to go.
I have run into trouble if I wanted to use the adapters mount when I have been using my Minolta 80-200/2.8.  The Minolta lens is rather fat and the tripod mounts I've tried get stuck on the lens before you can mount it to the adapter. But the lens has a mount.
