Lens for $14 and Sony a7rII
Ilya
Lovely effect! How does this work? Is this just a lens adaptor?
it work quite simply :) Custom helicoid 62,5 мм and that is all. Most projection lens has 62,5мм diameter. No diaphragm, no blend. If you are interested, I will post photo of helicoid.
