Sony A6300
No -  the 30mm macro lens only  is attached to the A6300 for the copying and the other method is the A6300 attached to the Nikon PB4 bellows via a Novoflex adapter but at the end of the bellows is a Componon enlarger lens which was slightly better than the 85mm Nikon lens I used to use.The working distance from the subject with extension tubes with the 30mm macro is so small I am sure using the bellows would be hopeless. The autofocus using extension tubes with the 30mm works Ok with the A6300.
